Question fast CX
09 Feb 2010 09:08Wer fährt denn mit sowas???BAM6868 postete
Das sind vermutlich Pirelli P4000.
Grüße,
von Peterle, der gestern seine nigelnagelneuen XWX aufgezogen hat.
- BAM6868
09 Feb 2010 07:52Das sind vermutlich Pirelli P4000.Frank Joh S. postete
Im ersten und letzen Film muss mal watt geölt werden. Da quitscht es dauernd.
- Frank Joh S.
09 Feb 2010 00:06
05 Dec 2009 17:39Nee, Peter, leider ist das Auto aus "Gekotzt wird später" in dem König Werner mit einem Oldsmobil in die Ferien fährt.P.Biehl postete
Datt mutt kesseln!
Kesseln mutt datt!
Im Kessel Film spielt ein Bentley Blower eine Hauptrolle. Der Herr Brösel ist wirklich Motorverrückt!
- Josef
27 Nov 2009 18:49im gleichen Forum gibts nen Engländer der hat seinen CX Turbo mit einem Kit für 600.- Pfund auf 250 PS mit 317 Nm bei 3500 rpm getunt.
wäre mit obigem Wagen doch ne nette Geschichte.
Josef H.
Auszug aus dem Forum:
E658 LVC started off as a standard CX GTi Turbo 2, which was a quick car with the 168bhp as standard - but when a Maikonics Kit and Bespoke Maikonics exhaust system are added...they are a completely different car with
250BHP.
Now, for those that don't know what "Maikonics" is, which I suspect it is for most of you! here is a brief summary:
Simon Greenwood is an electronics consultant and he did CX conversions through his company, the hardware is his doing and he fits and sets it up. The stage 1 was around £600. From memory the stage 1 torque figure is around 317 ftlb @3500 rpm, it can light up the tyres in 2nd from standing at the lights ETC.
Basically Simon was a victim of his own success - so many enthusiasts phoned him , at any time of the day or night, that in the end he couldn't get enough work done . So he moved on .
Stage one consistes of;
- ECU Conversion. Enables igntion timing to be retarded / advanced according to boost pressure, he quotes "upto 35 psi". I have talked to many many Superchip, Starchip and associated piggy back system suppliers and no one else can or is prepared to do anything for the CX as it's an oddball set up.
- Wastegate modification. Enables the boost pressure to be altered to suit, up to 15 lbs on an intercooled car (T2) and a different (stronger) spring is fitted.
- New platinum NGK plugs. The difference can be noticed if you run them on lesser plugs.
Well, thats some basic history and my CX is running the Stage one tuning kit. This is all you would really want to go as they will rip clutches out if they have a slight hint of it slipping. An example of the greatness of this kit is at about 110mph, when accerlerating away, it feels like you are at 40mph and accerlerating!
- John
13 Nov 2009 18:30Ich sehe immer nur einen CX mit SM-Front. Gibt es ein Bild von einem mit XM-Front? Oder habe ich was nicht mitgekriegt?Lutz-Harald Richter posteteSoweit ich weiß, handelt es sich dabei nicht um einen Prototyp, sondern ein privates Zufallsprojekt. Da wurde an einen CX-Unfallwagen die damals relativ neue XM-Front angebastelt, aber ziemlich professionell gemacht. Es gab darüber einen Zeitschriftenbericht (ich meine es war in der "Voila") und es gibt auch ein 1:43 Modell davon.MaTHias postete
Ich hab mal gehört, Daniel Kunz hätte mal für einen Kunden an einen SM eine DS-III-Front gebastelt. Kann auch nur ein Gerücht gewesen sein.
Den SM-CX kann ich nicht mal vollständig ablehnen. Sowas gab es ja auch von Citroen "original", einen CX mit XM-Front; einer der seltenen Prototypen...
Lutz-Harald Richter
- Jan Paul
13 Nov 2009 16:40Macht ihr mal. Chromspeichenräder würde noch gut dazu passen und ein Heckflügel vom Ford Sierra XR 4i.Frank Joh S. postete
Trotzdem gut gelungen. Auch die hinteren Backen sehen lecker aus.
- Lutz-Harald Richter
13 Nov 2009 12:06Soweit ich weiß, handelt es sich dabei nicht um einen Prototyp, sondern ein privates Zufallsprojekt. Da wurde an einen CX-Unfallwagen die damals relativ neue XM-Front angebastelt, aber ziemlich professionell gemacht. Es gab darüber einen Zeitschriftenbericht (ich meine es war in der "Voila") und es gibt auch ein 1:43 Modell davon.MaTHias postete
Lutz-Harald Richter
- Stefan M
11 Nov 2009 22:32SM
- Frank Joh S.
- Sonja
11 Nov 2009 13:27lg
10 Nov 2009 20:20Den SM-CX kann ich nicht mal vollständig ablehnen. Sowas gab es ja auch von Citroen "original", einen CX mit XM-Front; einer der seltenen Prototypen...
- Jan Paul
10 Nov 2009 09:23Beste Grüße
